Ac compressor making noise
TorqueAutoMotiv
donated to get this wow
Let me rephrase it makes a horrid screeching as if something were diing a horrid painful death
Is there anything that might beable to make this subside till i can fix this properly
I was thinking about just doing an ac delete pulley till then but I dont know
It makes noise no matter if its on or off i may pick up a ac delete pulley cause its a cheap fix
I think the ac comp isnt sitting properly right now looks a little off Im going to pull it off and check it out
the a/c should cycle on and off with the heat on when its not on full blast, this helps add moister to the incoming air.
It just makes noise regaurdless no air on no heat on gets worse with the heat on but not by much
What do i need to replace the clutches any specialty tools?
Im going to have to do something its annoying as all hell
Welcome STEFAN MUELLER
Leading source of Online Diagnostic & Repair Information
ACCOUNT
VEHICLE
HELP
SEARCH
CONTACT
EXIT
Your Vehicle: 2000 Pontiac Grand Prix V6-3.8L SC VIN 1
Vehicle » Heating and Air Conditioning » Compressor HVAC » Compressor Clutch Bearing » Service and Repair » Clutch Rotor and/or Bearing Removal » V5 - Conventional Mount Notes
TOOLS REQUIRED
J 6083 Snap Ring Pliers #24 External
J 9398 Rotor Bearing Remover
J 8092 Driver Handle
J 33020 Pulley Puller
J 33023-A Puller Pilot
Remove the clutch plate and hub assembly.
Use the J 6083 in order to remove the rotor and bearing assembly retaining ring.
Install the J 33023-A to the front head.
Install the J 33020 into the inner circle of slots in the rotor.
Turn the J 33020 clockwise in the slots in order to engage the tangs of the puller with the segments between the slots in the rotor.
Hold the J 33020 in place. Tighten the puller screw against the puller guide in order to remove the puller rotor and bearing assembly.
Support the rotor hub in order to prevent damage to the pulley rotor during bearing removal.
7.1. Remove the forcing screw from the J 33020.
7.2. With the tangs of the J 33020 still engaged in the rotor slots, invert the assembly onto a solid, flat surface or blocks.
NOTE: It is not necessary to remove the staking in front of the bearing to remove the bearing, however, it will be necessary to file away the old stake metal for proper clearance for the new bearing to be installed into the rotor bore or the bearing may be damaged.
Use a J 9398 with the J 8092 in order to drive the bearing out of the rotor hub.
Account | Vehicle | Help | Contact | Exit
© 2010 ALLDATA, LLC. All Rights Reserved. Trademarks | Privacy Policy | Terms and Conditions
Ok so i got my a/c delete pulley today
Any one on here with one it came ith some bushings and washers to use as spacers just curious if any one had alignment issues
did mine today in about an hour and a half...no biggie and cost $58 . better than 260 when it still worked great just noisy. now nice and quite qnd still works great.
Did your pulley for $58? or replaced the whole unit...? Mines going bad now and I'm unsure what to do at the moment... I dont want a belt snapping on me leaving me stranded...
My compressor pulley is grinding and spitting shavings also. There is an aluminum tube coming from a hose fitting near the firewall under the master cylinder that has been cut and pinched off. It seems like a royal mess and I dont have the money or time to deal with it. I DONT want to throw my belt if the pulley seizes on me so should I..........
A. Replace the bearings in the compressor
B. Remove the compressor and install a bypass pulley.
Looking into the engine bay I stumped as to how the compressor can even be removed. If I replace the bearings, how long until it has to be replaced again?
