ABS Traction Off Light
Phrozen99
My 1999 grand prix gt has intermittent ABS + Trac off lights. I heard it was the wheel speed sensor, and that it's inside the wheel hub. Thoughts?
yeah, you'll have to check it wit ha code reader and see which wheel it's in. You'll have to replace the hub. Expensive fix I believe, but don't quote me on it lol
Mine was the same, then became a permanent ABS light/trac off. Front driver side had some broken wires.
The wheel bearing has the speed sensor built in.
Couple hundred bucks for a quality replacement like SKF with a warranty.
Buy some new bolts too because I had to saw one off.
It's easy to do.
