lightsgalore
Been having this issue for awhile now,, it started when I would hit holes in the road(not on purpose of course). Abs/traction control/service variable effort steering/service brake system all would light up. Once I would kill the car and restart, it would clear all the faults. At times I would pull in or out of my driveway and the car would slide-- traction control would come on.
Last time I had it at the dealership, I was told it was either the wheel sensor or the wiring harness. As of then, they could not trace it down, and they did not want to replace something that wasnt the cause. So I was told to drive it til it got worse.
Now, all the lights are on and will not reset. So the other day I had the wheel sensor replaced. Didnt fix it.
Now Ive noticed a bad shake when accelerating. So I had my tires balanced-- didnt fix it. So I was thinkin-- maybe bad cv joint.???
I took it to another tire store today-- just to make sure the tires were balanced b4 I started worrying about replacing things. They had a mechanic drive my car-- sure enough-- he thinks bad cv joint. He was also so kind to hook up the scanner to find my warning light issue. He said the codes are saying- ECM. He told me that there are 2 different ECMs. 1 for the ABS,, and 1 for the main computer. However, he said it didnt specify to which 1.
So my 2 questions are---
Is there anything I can do to determine which ECM it is other than just replacing 1 to see if I got it right.????
AND
as for the cv joint-- he said theres no way of determining which side it is right now(its not makin any noise,, its just a bad shake).-----Surely there has to be a way to figure it out...?
Any suggestions?
AND
Any suggestions?
