ABS/TCS lights
armyrebel03
I have a 04 GP GT. The ABS and TCS lights have been coming on and staying on. I read on the forum that it could be the speed sensor for the wheel hub. If its the sensor, can u just change out the sensor instead of the entire wheel hub, or just go ahead and change the entire assembly.
Must change the assembly. Don't go cheap or you will be doing it again in about 3 months to a year. Buy brand name such as Timken from Amazon or Rock Auto.
OK, thanks for the help. Also, is the car safe to drive like this, I'm not seeing any ill effects from the lights. The lights come on at random times.
Its just the ABS now but the wheel bearing is going bad and the ABS is the first sign. Wheel bearing isn't going to die today but it might die within the next month. I wouldn't take any long trips.
