abs light
GTByron
Noticed that my abs&trac light will come on if I hit a bump on the driver side front tire. It doesn't always come on when I hit a bump but it does it sometimes...any suggestions?
like these guys said, or a bad hub, just had to change one myself, if i was turning and if i hit a bump the light would turn on.
jack up each wheel, lugs tight, see if you can feel any movement out of the front hubs, is so the hub is bad.
