ABS help
GTPJAY
Don't know if the abs sensors are a common problem or if this is even my problem but it seems when I am turning left sometimes my abs kicks on then off and then my light comes on shutting of the tcs. Any suggestions?
Although I have never had a problem, wheel speed sensors seem to be a very common cause for what you are seeing. Between the speed sensors going bad, speed sensor mounting coming lose, and sometimes it is the wheel bearing going bad that sets off the speed sensor causes a lot of issues.
I know for sure there is no wheel bearing issue as this was all done when I bought the car. There is always the possibility of a defective one I guess so I will focus on the sensor. Thanks
ABS sensor is in the wheel bearing which requires you to replace the wheel bearing to fix. Kinda a sad situation. Check the wiring to make sure it hasn't been frayed, shorted or mangled somehow.
same problem here!???? replaced front wheelbearing. didn't go away. makes a wiered noise when it happens to here
