ABS, Check Tire Pressure and Air Bag Lights On
jpearsall187
I have a 97 GTP that I had to drop the engine cradle on this past weekend because a power steering pump bolt had broken off in the engine block and I had to remove it. Once I got everything back together, I noticed that when I turned the car on the ABS, Check Tire Pressure, and Air Bag lights come on and will not go off (The air bag light actually flashes a couple times on startup then stays on). This sound like wiring problem?
Yep, sounds like an ABS sensor is not connected good at one of the wheel bearings. Not sure on the Air Bag light. May want to scan for codes on that one.
Ok, will check those. Is that a common ground for those three systems? How does the wiring run behind the engine for these? If it was just ABS and Tire Pressure, I would suspect the sensor near the wheel, but with the air bag on, I'm not sure.
