ABS and track off lights
probuilder1
Well I replaced my passenger side CV shaft about a month ago and my ABS and track off has been coming on and off now it is on all the time. Would you say its a wheel bearing or would it be from somthing I did when changing the CV? Kind of a dumb question but will my ABS still work?
i had to change my wheel hub for my car it had the same light problem but after that it was fine, if it is that you will see that how the have the sensor were it is it is in a bad spot and thats why the sensors get mest up
Wheel hub(s)
Also be sure you're posting up in the correct section. That way you're question yeilds the best results.
