ABS and trac off lights
probuilder1
Well I replaced my passenger side CV shaft about a month ago and my ABS and track off has been coming on and off now it is on all the time. Would you say its a wheel bearing or would it be from somthing I did when changing the CV? Kind of a dumb question but will my ABS still work?
If your car has more than 75000 miles the wheel bearing is going bad, less than that, it might just be a bad connection. If your abs light is one your abs will not work!
I am having this happen to my 02 GP... I just had my hubs replaced 2 months ago and I believe they are the original sensors in the hub, not part of the hub replacement. I am leaning towards checking my sensor connections and cleaning the sensors themselves as I have researched this issue and they seem to collect a lot of road gunk. :th_praying:
Post back my results in a few days...
