ABS and Trac Control Lights On
itfrg
I have a 1999 Pontiac Grand Prix. Today the ABS and Trac Control lights came on. I tried shutting off the engine and have them reset. When I started the engine the lights were off. Once I started moving, the lights came on within a quarter of a mile.
Any ideas?
Thanks
bad bearing.....or bad EBTCM(ABS module)....i have the same problem and i think its my EBTCM as i replaced both front bearing and they are still on.
Had the same problem - replaced both hubs one was growling anyway still had intermittant abs/tcs - after closer look found Bubba had spliced the abs wiring in two spots with a twist and tape. I re-did the slpice with solder/heat shrink Lights have been off over a month now.
You can't rule out a bad rear hub either. I've had a rear hub fail and cause the same problem. Best to have somebody scan it with a scanner that will read ABS codes. Standard OBDII scanners will not read ABS codes.
