CSteen85
Okay, here are my two main issues:
I had a friend work on my car for me. He took the tires off and checked the meat on the brakes and he said next oil change. Now that the tires are back on, the driver's side tire rubs against something when I make sharp right hand turns only.
I think it's rubbing against the wheel well or the fender wall, it's this little piece of hanging plastic. So, we cut that little piece off and it's still making the sound with those turns. It's definitely grinding against plastic of some sort and only when the wheel it at a certain angle in the well.
Could he have put the tire on wrong? He said the tires are big for my car, but it wasn't doing that before he took them off.
Secondly, there is a part that I can't find the name of. It's a rubber or plastic t-shaped piece that connects a vacuum hose to the engine I believe. I got a check engine light and the scanner said I was running "too lean," and he could hear that there was a leak in the vacuum hose, but I can't identify the piece to order another one. I'll take a picture of it tomorrow and post it, but if anyone knows the name off the top of their head, that'd be great.
Thanks!
Thanks!
