industrialfish
2005 GTP. Passenger floor completely full of water.
When I pull up the carpet, where the door bolts to the frame, there is an access port where the door wires go, that is completely full of water and its spilling onto the floor. There is a tube in there that goes upwards, and if I blow in it, it's completely unclogged, presume thats the AC Drain, but I do not have working AC, and it's been sitting for months.
Got the deflector fix from a junkyard and sealed the cabin air box. If I pour water into the cowl, it drains out cleanly behind the wheel.
Sunroof seals fine. Pouring water onto it while closed results in all the water going down the roof rails or windshield and draining out the cowl.
I assume there is supposed to be a drain to the outside, where the door bolts on if that is the AC drain, but I couldn't feel anything other then a couple blobs of foam sealant.
