Hello everyone! I have a 2000 GTP.
I have 2 issues.
#1 The power steering line broke. It's the line that goes from the rack to the rack. It looks about the size of brake line and not the size of the return line or high pressure line and it's not a long line either. There's not a lot of room to torque a line wrench to remove the line. The fitting is on the junction that's near the drivers side wheel. Should I cut the line and try to remove it with a socket? Is there a better tool I should buy? I doubt I can get a socket in that small space. What I want to know is it only a dealer part? Has anyone else ever replaced it before?
#2. I changed all my brake lines. I bled them properly and have full pedal when the car is off. When the car is on, the pedal goes to the floor. I have to pump it up to get pedal. When I push the pedal, the RPM's jump a bit. Do I have a vacuum leak? I found a small home in the hose to the brake booster and taped it up with gorilla tape. I'll replace the hose soon.
A little history: The car sat for about 8 months. The rear brake line blew and I let it sit until I decided to fix it again. Before the brake line blew I did the upper and lower intake gaskets so the engine runs good.
I have 2 issues.
