A/C syetm
chocolatcolumbo
I'm just about to redo my A/C system in my 2000 GTP because my compressor went bad. I'm replacing the compressor, condenser, orifice tube, and accumulator. I plan to Flush the whole system and evacuate for atleast an hour after installing all the new parts. This will be my first time doing AC. Does anyone have any good tips or writeups? Thanks!
Have fun getting to the orifice tube :D
Have some new O-rings handy since you're opening everything up and may need to replace some. Should be the green O-rings IIRC.
Make sure you use the correct type and amount of PAG oil. Once you get it drawn down to the 29Hg mark close it off and keep the gauges on it. It shouldn't drop if the system is sealed. Once you have a good sealed and vac'd system I'd take it to a shop and have it refilled.
