Decided to tackle the A/C issue in my GT. Here's what I know: The compressor kicks in and stays in when A/C is on. With ambient temps around 88* and the engine at idle the low side shows ~30psi and the high side see around 110. Bring the RPM's up to around 1500 and keep it there and they slowly rise. Low side gets to around 60 and slowly comes down and high side gets to 190 and no higher. Let it back to idle and can hear the compressor click a few times (almost like a cycle click but it never disengages the clutch) and the pressure returns to the 30/110 area.
The pressure cycle will repeat itself if I leave it idle long enough. I never see the high side go higher than 190.
I have dye in it and do not see any leaks. I evacuated the entire system tonight and pulled a vac down to 30 Hg and let it sit for 15 min. It showed it was holding a vacuum so I refilled the system. After the refill I get the same results. Also, the vent temps are no higher than ambient temps. I do not have dual zone A/C, all manual and the door is working as when I switch it to heat it changes and I get even hotter air (if that's possible).
Both fans come on when I have the A/C on as well.
What I did notice is that the smaller line that goes into the Evap coil is cool, but the larger line on the low side is not. I thought that that low side line should be cold and the high side should be warm/hot as it comes out of the evap? Oh, and once the system is off the low side stabilizes at around 90 and the high side at around 100.
My thought is that the compressor is bad but willing to entertain other ideas before I tear it out and replace it.
