99 GTP WIERD problem...need HELP ASAP!!
LSXHP
Ok so I posted this in the electrical section but figure this is probably a better spot for it...
Ok so im going through the car wash last night and my climate control starts counting up from the 33 it was outside all the way to like 86 or something, then the lights start flickering on the unit. I turn the headlights off and it gets brighter like its supposed to but dont flicker, then all the sudden ALL my dash lights shut off as if I shut the lights off, DIC and everything else got bright, so I turn the lights back on. Then I notice the fog lights wont turn on. Had to be somewhere so I figure ill look at it today, hr later get pulled over because my tail lights arent working!!!! They light up when I use a turn signal or brake but not just when the lights are on....then I get where im going and I shut the car off, open the door and the chime is ringing all quick like I left the lights on but there off!! WTF is going on with this thing?!?!?:th_angry-censored:
oh also my DIC has been flashing all 0.0 for some time now as soon as the car moves st starts doing that and the TC is always off, I cant turn it back on....This car is really pissing me off....kinda wishing I never got that valvecover recall done...
try unhooking the battery over night, let the computer reset, have you checked all the fuses, even the ones under the hood?
Well got my lights fixed...turns out it was a fuse, go figure. Never seen a blown fuse cause so many problems at once, but im glad and suprised, nothing ever is simple for vehicle repairs for mme lol it always ends up being something major and expensive. Also took the DIC out and took it apart, everything looks good but it still dont work, just flash's all 0.0's. Also noticed once I turn the key to the run position its about 9 seconds until it begins to flash, unless I start the car and move it then it begins as soon as I move the car.
