99 gtp trans into a 2004 gtp?
So other than the range position sensor everything else should be ok? I'm not worried about radiator connectors, that's a simple fix. There isn't a difference in PCM control of the trans or anything?
Thanks for the link Scotty useful info for sure
Valve body, channel plate, and wiring harness is different.
Swap all that out and you'll be good as long as your gear ratio is correct.
