99 GTP Rear humming noise
Cbierniat24
I recently replaced studs on my rear hubs and now there is a humming noise above 35 mph. Could it be the studs not being seated properly cause this or bad hub from overkill with my best friend hank the hammer? :th_jester:
jack up car and grab top and bott of the tire and try 2 wiggle it from front 2 back. If it has play in it then the bearings ar bad
No play with either tire. I've also had an alignment done recently.
This is extremely annoying
Tire somehow came out of balance? Warped rear rotors?
