'99 GT weird problems
farmerchad
Hello, new member here, have a '99 GT. Every day when when I drive it the engine will stumble for a split second and the the "trac off" light will come on and the tach goes dead, can't see anything else not working, also when it does this engine runs but will knock and ping if I accelerate. Also if I'm idling at a light when this happens the engine will stall. Stays this way until I shut it off, then when I restart, everything is back to normal, tach works, 'trac' light goes out, engine doesn't knock. Could this be a ECM problem? seems like unrelated symptoms.
Thanks
