mikedinthecity
had a 99 gt plastic intake 3800 vin k come over and seems like it is running lean, rotten egg smell after driving lil on the harder side just putting it under load so i can feel the miss.....i changed the icm witrh a used one and it ran smooth. i havent seen a code yet. after restarting it and driving it searching a noise when you turn, i come back let it idle and go to rev it and theres the identical miss. it seemed to clear up and all but smelled like rotten egg after reving. all the iat coolant temp throttle posittion, both o2s, maf, map, all are reading correct. i took the module in to test and it failed, do you think simply the one i put on is faulty also, coincedence? or something make them both fail . any info would be helpful. new plugs, new wires, new coils. new polastic intake..this my first time attempt at this one.
