99 GPGT Passenger inside door lock and key lock not working at all.
71gs3504sp
Passenger door look was working off and on for a while with the key fob now nothing is working. I tried the key to open the door and nothing works. Seems like it's jamb now, can't open the door. What could it be? What needs to be replaced? Just to make it clear all the other three door work perfectly just the passenger door is the problem.
will it unlock manually? most of the time the plastic ends ont eh rods break then the rod has play in or it falls out of place.
or the lock actuator went bad.
not to be an asshole, but theres a lever on the inside of the door, aka manually with your finger unlock it.
cause if you can open the door at all your kinda fvcked here. the inside door cover needs to come off.
Actually I did get the door open by getting the door panel off, so your comment is being an ass hole! LOL!
I guess I can get a complete used lock actuator and see if that works!
