SMM2469
Hey Guys. I have a 1998 Grand Prix GTP with the following mods, see below. I have yet to run this vehicle at the track. What should I expect to see 1/4 mile time? Please advise.
· Supercharged Series II 3.8L GM Engine (Fresh Rebuild 10,000 Miles Ago, Stock Internals)
· GM Transmission w/ Performance Shift Mode Selector (Fresh Rebuild 30,000 Miles Ago, Stock Internals)
· 3.3” Stainless Steel Modular Pulley System
· Stainless Steel Header Kit with 3” Cat-Less Downpipe
· Custom 2.5” Dual Exhaust w/ Twin Moroso Spiral Flow Mufflers
· Custom High Ratio 1.9 Ratio Rockers Kit
· Custom Fender-Well Cold Air Intake Kit
· ZZ Performance Custom Tuned PCM Engine Computer
· Custom Ported High Flow Throttle Body
· ZZ Performance Throttle Body Spacer Kit
· ZZ Performance Throttle Body Heat Shield Kit
· Custom Ported & Machined Lower Intake Manifold
· Triple MSD High Voltage Coil Packs Kit
· ZZ Performance EGR Block Off Plate
· ZZ Performance High Volume Oil Pressure Kit
· 180 Degree High Flow Thermostat
· Meziere Heavy Duty High Flow Electric Water Pump
· Casper’s Electronics High Voltage 1.5 Volt Booster Kit
· Autometer Vacuum/Boost Gauge Kit
