98 GTP - Turn wheel and brake, makes vibration in pedal and noise
mram10
Just like the title says. I push on the pedal in a slow turn and sometimes I get an antilock brake pulse type feedback in the brake pedal. Thoughts?
i would say u have a wheel bearing going out or a abs harness that has a short in it mine did that when the abs harness had a break in the wire or a small break not always open
Sounds good. I will check the pads, then move on from there to the wiring. The bearings probably need replaced. Is there a good DIY for the bearings?
