Hey everyone, I have a 98 GTP with 255k miles on it. Once in a while, typically after 15-20 cold starts, the car will start, and die almost instantly. Today, for instance, the car started and died 5 times in a row before it would stay running. When it does finally run, it will idle very rough for about 3-5 seconds and smooth out. The car runs fine any other time, and most starts it has no problem. I had an issue in February where the car idled rough when warm and set a code. This ended up being a cracked EGR tube which I replaced with a new tube from the dealer. I also took the time to clean all the carbon from the throttle body when I did this.
I have a scanner and can check the fuel trim when running, and it doesn't seem to have a vacuum leak when warmed up. I have checked the fuel pressure. The car has about 55 psi when you turn the key, then drops to 50 after the pump stops running. I have seen it as low as 44 psi while idling. The car does have the new fuel pump resistor installed. I also checked the fuel pressure once when the car started and died, but it was right at 50 psi and the car started fine on the second try. Fuel filter was changed back in February when I was diagnosing the rough idle. I am unsure if the pump is original (I hope not) or if it has been replaced, as I've only put about 20k on the car myself.
Last summer I replaced the intake manifolds, injector o-rings, and some other top end items when I had the front cradle out of the car for a transmission swap. I have also replaced the plastic vacuum lines around the supercharger with rubber hose, as the plastic was brittle and cracking.
One issue I do know of, is that the rear manifold has an exhaust leak when cold, but goes away after it warms up. It hasn't been bad enough for me to repair yet, considering what a pain it is to get back there.
I've done my research, and haven't found many people with the same issue. I have seen someone recommend that the crank position sensor could be bad. Is there any way to test this?
Thanks for any input!
