the 97 GTP has the 4t65e, so its not vacuum controlled. only 97 SE and GT came with the vacuum one.
Yep and IIRC (trannyman would have to comfirm this) later year SE/GTs in 97 got the 4T65 instead of the 4T60 (vac controlled) tranny.
GTP has always has the 4T65-HD in the 97-03 GPs...
97 was still vacuum controlled with the 4T65-HD. 98+ had the 4T65-EHD (electric).
Also the supercharger has a different vacuum routing, evap system is different, the airbox, abs pump, pcm, washer & coolant bottle locations, HVAC color is green, DIC doesn't have tc as previously stated, a lot of 97 only had a manual lumbar (I got lucky and have power), most 97 have a full antenna instead of the window antenna, the vacuum controlled trans as previously stated, tb...that's all I can think of atm...
i've got power on my 97
