97 GTP The White Ghost aka Pearl
Well, here I go, I'm starting the porting job on the supercharger. This is what it looks like now.
When I finish I will post the final product............
This is where I'm at, at the moment, it's time to go to work now. I will finish where I left off at tomorrow.
And I think I'm doing good!
Looks good to me! gunna smooth it out with a dremmel or something? i also put a slith round on the edges to help reduce the chance of a piece cracking off.
That's what I'm going to do and polish it to make it smooth. In the corners, where I cut the pieces off, I'm going make them round instead of pointy looking....lol
If I put a cam in, what other mods do I need to do. Intercooler, rockers, etc..... Or can I leave the current mods I have I'm signature
No you leave the stock rockers unless you decide you want more lift.. Intercooler is also not required and can be done at a later date if you choose too.
Have a look at my hack job.......Lmao, but I'm not finished. I started off good, but I think it got a little worse.
I some Knicks on the mounting surface, also. that has me a little nervous looking at it.
I think you are doing alright. i wouldnt go any farter with a cutting too. time to grind/sand to smooth it out. Try using the 1/2 sanding drum to get the bulk of it then switch to the 1/4 inch drum for the tight corners. You got this!
I finally finished porting and polishing the blower outlet.
It wasn't that bad of a project....besides all the aluminium particles and foggy safety glasses....lol!
Here is some pics..............
I know, I have not been around in a while, but it seems like something always comes up, that is more important, when I'm about to work on her.
Anyways, I painted some parts anodized Metallic Blue. By the way this is my first time painting car parts and yes I know I should of hung the parts up, it probably would of looked a lot better. I had some dripage in some spots. Some over spray on other parts, etc... I did this outside because I had no where else to do it. It was real windy out there and it made it a little more difficult to spray 6 inches away, so sprayed a little closer to the parts and it started some dripping. Overall, I learned a lot on spraying car parts in this process.
Some suggestions, if you consider doing this.
1. Hang your parts, it makes the job a whole lot easier because you can get a good spray all the way around the part without having to wait for one side to dry and then flipping it over and doing the other side. Also, you can get even coats of paint, which will be better as you can imagine.
2. Where a respirator or dust mask! You don't want rainbow burgers...Lmao. You don't want to inhale the paint unless you want to get super high. Seriously, just think about, if spray paint got in your lungs. Just a thought! I was hacking up blue paint because I wasn't wearing my respirator. My American Bulldog chew it up into pieces...Lol.
3. Do your spraying projects inside/indoors because of wind, debris and other particles that may be floating around can effect the overall look of your projects. For those of you that don't know, TRUST ME!
