97 GTP engine codes
willy4x4
hi i have a 97 GTP with k&n air filter, lowered, 3" dual exhaust,freshly rebuilt stage 2 transmission.the car runs great but from an idle in park there is a slight lag when you firt rev the motor,,, as in rpm tends to drop a little then picks right up.everything look conected and in the right place.
i am getting 2 codes,the first is p0102 mass air flow sensor, i did change this map sensor after installing a new k&N filter so it was dry and not to contaminate the sensor, the second code was p1655 evap emissions purge control solenoid which i replaced also but tend to get this code once in awhile, the car has new iridium plugs in it also, another thing i notices is i only get half boost on the gauge even at full throttle,also there is less boost the faster you are going example only get 1 or 2 bars boost when at 120 klm and you giver.any idea on this will be greatly appreciated.....:th_thumbsup-wink::confused:
I'm going to say a vac leak. Most likely at one of the boost bypass solenoid lines and possibly at the purge solenoid line.
i noticed that the vacuum line that goes to the evap canister. it dosent go to the canister because there seems to be no canister lol, the vacuum line goes under master cylinder and plugs into one of the metal lines running alone side the metal fuel lines runing to the fuel tank.does anyone know were the evap canister it to be located?also were is the best place to find a canister? also looking for a complete vacuum diagram for 97 gtp.. thanks for the help so far ....greatly appreciated :th_nanana:
Here is a diagram for you
