97 gp gtp (dic)
All you need to do, is take off the dash which pops off, then the DIC pops out of the dash... unplug the unit.... Then the fun begins there are 5 or 6 tabs that you have to push in to get the back of the unit off.. Once you have the back off and access to the electronics there are 4 blue bulb holders. Be careful when you remove these since they are directly connected to solder points. After you get the blue holders off the DIC simply replace the bulb.. Instead of pulling on the bulbs and damaging the bulbs there are holes on the back of the holder so your actually pushing out the bulb instead of pulling.
