97-03 Climate Control Hack
04CompG
I was thinking today about when I had my 99 GTP with the climate control. I had read on the other forum back in the day about this trick you could do with the CC. You press both knobs in at the same time and hold it for a few seconds then you can see your speedometer digitally on the CC screen. I think you could also get your trans temp and **** too. Do any of you guys do this, if so what else can you read on that?
Yeah, it's pretty neat. There is a list somewhere that lets you know what all the settings are.
I'm pretty sure it's on ClubGP somewhere. I'll grab it if no one else has found it by then.
To enter diagnostics mode:
Press and hold both the Driver and Passenger knobs in simultaneously until the display changes to read "-00". To change position, turn the Driver knob to the desired number and turn the Passenger knob one click to view the data for that position.
Position Description US Observed on mine Canada
-00 Error codes (List of Trouble Codes Below!)
-01 (servo position) 103-107 43-162
-02 (servo position) 128 120-202
-03 (servo position) 150 162-194
-04 CJ2 Fan Speed Low=15, 29, 44, 58, 71, 86, 110=High, CJ2 Unit will adjust to other increments as needed
-05 (servo position) 93 88-191
-06 (servo position) -152 00-252
-07 (servo position) 00 0, 34-255
-08 (servo position) -155 00-255
-09 (servo position) 00 0, 23-255
-10 ? 04 04
-11 CJ2 Vent Mode 1=Def, 2=Bilevel, 3=Auto, 4=Lower, 5=Def+Lower
-12 Engine Coolant Temp -60 degrees 80=104, 95=131, 100=140 Peak@135°F
-13 Actual Vehicle Speed in MPH
-14 (servo position) 00 21=0
-15 ? 39 44
-16 Radiator low fan turn on temp -106 207
-17 Radiator low fan turn off temp 196 199
-18 ? 50 51
-19 (servo position) 162-169 40-172
-20 Affected by cabin temp sensor 89 50-172
-21 (servo position) 00 ?
-22 Sunload Sensor -117 LIGHT=126, 218=DARK
To return to normal operation, press the MODE button next to the Passenger temperature knob.
This is a list of the Trouble Codes displayed by the CJ2 Unit.
A two digit code indicates a current fault while a three digit code indicates a historic fault.
Trouble Code Description
00 No System Fault
01 or 101 Inside Air Temperature Sensor Short
02 or 102 Inside Air Temperature Sensor Open
03 or 103 Ambient Outside Temperature Sensor Short
04 or 104 Ambient Outside Temperature Sensor Open
05 or 105 LH Electric Actuator Open or Short
06 or 106 RH Electric Actuator Open or Short
07 or 107 UART Serial Data Line Fault
08 or 108 Solar Sensor Open
To clear codes from the CJ2 Unit, press the A/C Mode button.
can yoy swap out a 99 climate control for a 98 one. (swap the one he's talking about with the 3 dial one) i hate mine
:th_scratchhead:
The only difference I know of between the 98 and 99 is most of the 98's had a green display....... Got any pics?
I think he's saying to swap out his 3 knob one, for the digital CC in which you can do this to.
I've tried it with mine and couldn't get it to work. Ah well, that's what the HUD is for :D
-10 ? 04 04
-15 ? 39 44
-18 ? 50 51
00 No System Fault
Very nice. Did not even know this.
The gray circular knobs/buttons on the dual climate control. I cant really remember what it looks like but its the knob on the far left and then the knob on the far right. but yea the driver and passenger knobs.
my 02 doesnt have knobs :( it has the lil things u slide up and down
Yeah the digital/electronic dual climate stopped in 2000. This is the one they're talking about, press the two big round buttons together!
I'm not sure if I'm asking to right section/thread...but I couldn't find any related issue.
I had 105, cleared it, and 105 again. I have been hearing a noise of the actuator keeps moving (trying to do something) that goes away when i turns on the fan and moves its direction a few times.
Is this something I can fix/replace?
Thanks,
MK
In my search for information on the dual climate control and the temperature actuator motor replacement, I figured I would bring back and old thread instead of making a new one since there are so many threads on this.
My '99 has the driver side stuck to around 70 degrees or so while the passenger side works fine. The thing is that when I turn the temperature up to 90, the driver side will blow nice hot air, so I know the motor is operating. Is it a common thing for it to only operate partially? I would think if it failed, it would just be stuck on one position.
I still don't understand how to read the diagnostic codes, either. I went all the way through "22" and wrote down all the corresponding numbers and never got anything that appeared to be a trouble code (01-08 or 101-108).
Is this CC unit compatible with later model years? IE, 2000-2002? Can the wiring be changed to make it work or does it need a different AC unit behind the dash?
It's been gone over before. You'd need the dash harness from a dual digi car in order for the climate control to work properly. You might also need the HVAC box. Not sure on that one. No one has ever done it to my knowledge. Good job on searching. Not many can do that. The last post in this thread was over 4 years ago if you didn't notice LOL
Yep I've swap one into a 97 GT when I was completely rebuilding it....I can't remember if you need the entire HVAC box, but you will need the inner workings for sure. Since it is dual climate, each side operates independent with its own actuator. Basically you need to find a donor at a junkyard, gut the entire HVAC box and outer components, remove the wiring harness (All one piece which is connected to the fuse block under the hood and the brake module, etc), and then rinse and repeat on your vehicle. It's a bunch of work and a major undertaking.....is it worth it? I dunno, maybe. I did the swap because I did a total rebuild and wanted to get rid of all the 97 stuff that was becoming a pain...ie 4t60e, electronics, etc. The donor I found at the junkyard happened to have the dual climate so thats what i went with. This is not a Saturday afternoon job. You'll need plenty of room to spread out all the parts you'll have to remove. Good luck!
