Dustindell
I've got a 1996 Grand Prix SE with 127,000 miles. I bough the car a year ago to drive to and from work, It has the 3100 SFI that knocks real loud at initial start up. Well a few months ago I was driving it home and noticed the acceleration seemed to feel bogged down. I limped it home and noticed the transmission smelled real hot so i figured it was toast. I bought a GM re-man transmission that was used and put it on, while i was doing that i tore down the motor and replaced most all of the gaskets excpet the head gasket. The first bolt i tried to take off stripped so i left it alone. I put everything back in the car, it fired right up. I put the wheels back on the car put it in drive and there are no issues what so ever with the car on jack stands. So i took the car off of the jack stands and back it down the drive. I start driving it down the road and the car spits and spudders, if you mash the gas it eventally takes off like it normally should and shifts fine. Once its up to speed you can hear the exhaust get really deep. If you try to accelerate when the exhaust has a deep tone it does the same spuddering then accelerates quickly. There are no misses or engine lights on the dash. I did replaced the fuel pump a couple months after i got the car because it went bad, i did the filter as well. I've used my volt meter on all the sensors in the engine bay and they all checked out as working (MAP sensor, IAC sensor, cleaned MAF, crank position sensor, ignition module). I replaced and checked all the vacuum lines. What should i look for next?
The main thing that has me puzzled is the fact that with no load on the tires the engine and trans run flawlessly but once you put a load on the tires its a completely different car.
Any ideas on what to check next would be appreciated.
