96 Grand Prix fender?
Apk07
I have a 1996 Grand Prix GTP and the drivers side is showing a lot of rust, and the fender/flare is falling off and coming apart. Anyone know where I can get replacement parts that don't cost $2341234 in shipping? There's no good junk yards around here, either.
You can fix that :) Get a good lesson in metal shaping, Welding, And body work :)
But on a realistic note. Car-Part.com--Used Auto Parts Market
Enter year make model and zip code, And find the item in the drop down. And hit search. Get to the next page, In the column of Distance/Miles away, Click it and it will show by distance. Nearest to you. Odds are there will be some within 60 miles, And just drive and get it.
You can use any '88 - '96 fender as long as it has the same B4U body/ground effects kit/package on it so that the holes for the clips that hold on the flare and moldings will be there. The only way to get an affordable new one is to go aftermarket, but then you have to worry about proper fit. Your best bet is to hunt one down at a yard, or maybe find someone on w-body.com who may be selling one/put up a wanted ad. Where are you located?
