95 Grand Prix GTP Stalling Issue??
james125
Hello guys new to the forum and starting to have some issues with my 1995 Grand prix DOHC 3.4L.
Ok so I bought this car for commuting back and forth to work car is spotless very clean with 150k on it but its been a problem since I bought it.
So when I drive it it runs ok I can drive it for hours but if i let it idle for more than 2-3 minnuts the thing will start to run rough spit n sputter and then die, and when it dies it will not start intill it cools down at least 1 hour and then it will run fine. I checked the shrader valve on the fuel rail and nothing but air comes out after it dies even while cranking only air will come out, So could it be a fuel pump I changed the fuel filter but that did not help and its not overheating? any ideas would be great thanks
Try cleaning the throttle body and IAC valve aswell as the maf sensor with maf cleaner.
Kinda sounds like the IAC gets stuck and causes the car to die out.
