94grandprix
ive been thinking about swapping a 94 gp engine with the 97+ 3.8 supercharged engine,they pretty much have the same space under the hood ,what would i have to do to make this possible,thanks
ive been thinking about swapping a 94 gp engine with the 97+ 3.8 supercharged engine,they pretty much have the same space under the hood ,what would i have to do to make this possible,thanks![]()
ALOT.
because of the year differnces and such. You can just drop on into the car. Lots of custom fab work and wiring.
im curious.... did the subframes match up?Did a swap from a 99 gtp to a 93 cutlass. Basically a drop in, we had to cut some of the firewall because we did headers. Also moved the upper motor mounts. The wiring harness was the most expensive thing to get done. Also need gtp axles to combine with your stock ones, gtp inners, stock outers, but use the gtp shaft for the passenger side. It would be wise to upgrade the fuel pump. You will also need power steering lines from a n/a 3.8l. There's more to it, but it really aint that bad.
