92 Grand Prix, will not idle right.
92GrandPrixSE
Specs on car: 1992 Pontiac Grand Pris SE, 3.1L auto.
I have been chasing a high/erratic idle since we bought the car. It will idle at 1,000 in gear, and in idle will climb to 2,000. I have replaced the IAC, CTS, TPS, all the gaskets from the lower intake to the throttle body, and the map sensor. I think it may be the comp... Any ideas will be great. Thanks.
check your vacuum lines for a vacuum leak. i think if you unplug the PCM for a half an hour and then plug it back in it will reset.
