90 grandprix A/C Bypass pulley install help!!!! ASAP
nissanboy86
Ok i have a 1990 Grandprix with a make of 9/89. My A/C Compressor froze up the other day so i went ahead and bought a A/C bypass pulley. The thing is how the hell do you install this? I'am a diesel tech and have worked on engine my entire life and can't figure it out. Here is a picture of the bypass pulley.
The block has on 2 non threaded holes also and the third hole on the bypass pulley does not even line up with anything... I know its the correct pulley (i think) 3 stores, pepboys, advance auto, autozone all carry the same exact pulley. It says to use existing bolts from the vehicle.... Well the pulley isn't threaded so that does a lot of good....
Any help would be very appreciated. As i need to get this done ASAP the car has the out of commision for 3 days now.
