4th Brake Light (Under Decklid)
drunknmunky
ok guys, after seeing a few local members pictures of their 4th brake light, and looking at my tinted tails everyday, i decided i needed a set of these for many reasons. there isnt much to explain the pictures say it all...
but if you have any questions feel free to ask...
and the kit is a universal "24 Red LED Strip (attaches with double sided tape)
First, remove the taillight (i choose to use the passenger side) by taking out the 2 screw style holders inside the trunk
Dont forget the third one behind the carpet
Next i tapped into the 3rd brake light for my source of power. others told me to use the taillight but that is a BAD IDEA!!! DO NOT USE THE TAILLIGHT. you can but its too much work. because you tap the high side of the bulb, which means when you brake it will work but it will also flash with the turn signal (on the side you tap) so just use the 3rd brake light.
I ran the wires inside the decklight and dropped it out outside of view and ran it behind the carpet for cleanliness...
Next i drilled 2 small holes in the car (one in the chassis and one in the bumper) just big enough for your wires to fit...
Next run the wires from the LED strip through the hold in the bumper and through the chassis hole also... i used silicone on the chassis hole to keep water out of the trunk.
Here shows where my wire came through from the whole in the chassis. it come through inside that channel.
A little joining of the wires and heatshrink and tape and your ready to finish up.
Little tape to hold the wires up temp till i figure another way to mount the wires...
This is the strip taped down to the bumper channel.
Lights working beautifully!
As you see here on my color you can kinda see the strip but it is really not noticeable during the day. i am actually going to paint the small "1/2 peice of the bumper to the sides black to make it blend better... and probably the top of the bumper between the tailights so it is as if there is one long black strip going across there (from taillight top to taillight top) I put one on my friend jose's black gp and it blends in smoothly...
Love the work Drunk! Now what would be really great is if you could actually say split the 24 into two seperate 12 LED sections and allow it to be used as an extra turn signal as well. I sure that could be done. Would be interesting to see how that would come out.
Like Syn said...........I got a new project to tact onto my already growing list :)
i think when i have time (im starting school) ill try the turning signal lights and post pictures and such for everyone
Just installed mine today after school only took like 20 min too, great little project... Instead of drilling I fed the wire through one of the wholes that the bolts go through to hold the tail light, a good idea if your afraid to take a drill to your car like me lol Im not sure if its working or not though cause I haven't been able to get anyone to check it while I hit the brakes lol... pics will be up tomorrow! thx
congrats... but be careful the bolts dont rub the wires too much and cause them to short out...
and just wedge a tool or ruler or something between the brake pedal and the seat (with it slid all the way forward) - thats how i did mine to test it
First I have seen that mod...looks very good...bet it would really blend nice on a black car (like you said)!...GOOD JOB!!!
I ordered my led bar yesterday. i cant wait to get it installed. I have a 03 Blue/Black GT. I think it will look pretty sharp...Thanks drunk
good luck chase... if you run into any problems let me know... it will look good and blend well on your dark color. i put one on my friends black one and it blends in so well!!!
post pics when you get it done
Hey drunk I will post pics when Im done. The only problem that I may forsee is trying to figure out which wire off the center brake light to tap into. All the rest looks easy enuff. I hope it gets here soon. Im pumped to get this done.
