4t65E replacing 4t65e-hd question
guitarguyucf
So yea, About 6 months ago I did a swap at a local shop and had them rebuild a 4t65e engine. I put it in my 99 GTP and it runs fine, just shifts ultra hard...Sometimes it sticks in 3rd gear when on the highway before doing a late shift into 4th...Ive read that the final drive ratios are different 2.93 hd, 3.29 for non hd...now my question is should I reprogram the ecm for that variable or are there other things that should be set...and also would it be the main computer or the transmission computer (the guy at this one shop said my car had one?)
umm, not sure on a whole lot on trans, but the PCM controls the trans, i do believe you would need a tune for the GTP trans, do some searching, sure someones ran into this. you could just do a out of the box tune from Intense but the shifts are controlled by two solonoids, a 1-2 and a 3-4 solonoid, and they shift when told to basically.
edit- Trannyman95 is your guy on trans problems, this is Dave from Triple Edge Performance, although i sent him a PM about a week ago about a trans problem and have never heard back, so you can try your luck
