4T65E Manifold Pressure Switch
TDgrand
I received today my purchased of a solenoid kit off Ebay for my 4T65E transmission.
4T65E Solenoid Kit 03 Up GM Shift TCC EPC Volvo New | eBay
I am concern about the Manifold Pressure Switch being correct. The pics are below.
Does anyone know which one is correct? Thanks!
http://
Here is the one listed on rock auto, I have seen this one in other threads and think it correct.
http://
I have another question, I have the p1811 code on at all times.
It came on last weekend, about a week after changing the trans fluid. My Grand Prix has 151,000 miles on it. Last time I changed the fluid was at 125,000 miles.
The trans runs pretty well with the light on, no issues. Is it safe the dive it until next Wednesday, until I do a shift kit and solenoid change.
You should be fine to drive that long. All the trans is doing is shifting you a full pressure. Typically it's a soleniod issue, so you aren't hurting that and you likely are letting off the power when shifting to keep from snapping your neck.
