Felix
On my 2002 GP GTP it makes a noise that is supposedly coming out of the transmission (Sort of like a single hit from two metal object), when I'm in the car it sounds like its coming from the right side of the vehicle. Also when I switched from park to reverse I notice the RPM sometimes drops from 1000 all the way down to 500, haven't noticed that before. Park to drive I notice that it does not make a noise and the rpm does not drop. Is that my reverse going out?
EDIT: The noise only happens when I'm switching to reverse, also when I'm at parked at an angle it becomes extremely stiff and needs a bit of force to switch the car from park to reverse.
EDIT: Already replaced both CV axles and trans/engine mounts.
EDIT: Need to replace tie rods and wheel hubs.
