3" Catless downpipe from zzperformance question
Joshmoshh
What are the Pros n Cons of a Catless Downpipe?
Is it worth getting? i know many people would suggest headers but nobody around me will do headers so ill just do plog and Downpipe,
i could possibly find a guy that can pass my emissions like a lick n stick but was wondering the advantages. thanks in advance :)
Nothing really, other than a little more noise, slightly better MPG's...and a smidge more performance you probably won't notice compared to a catted one. If you can get away with it, run catless. If you can't pass a test without one, then just get a fake cat from Frozen Boost.
Good thing about getting rid of the cat?
No chance of it ever failing.
^ This.
Since your rocking a 98 GT (per-profile) you don't have the flow to worry about with supercharger mods, but it will still get rid of the u-bend and get better flow should you decide to top swap or do other mods.
Not as good as headers and cost almost as much. (Speed Daddy headers complete $225ish shipped)
High flow CATs are still known to set off CEL lights on some cars/year models. 98 shouldn't matter, but it could
Ah... need to update that then.
Being supercharged, the DP will remove the U-bend, help flow, remove some KR, give a little tone.
If you plan to mod tho, skip a DP and just get headers. Before you can do a pulley drop to pull more ponies you'd have to have headers anyways so you'll just be burning money. If you plan to stay stock and just want a little extra, get the DP.
Sheff, dont even give the option for a DP.
Just buy Speed Daddy Headers off ebay, $217 shipped to your front door.
If your doing a Plog and DP anyways, just go for headers. Honestly.
already have the dp on the way, already :(
I was thinking i could still drop to 3.4 with downpipe and plog, i dont plan on dropping any farther just 3.4 .
Don't know until you scan.
With these cars getting older, I doubt it.
That's why we always say: headers. maximum flow gains for the same price.
hey mann, age is just a number. My car is rust free, new tranny, new bottom end.. with 267k miles.
muh car is a straight up tankk baha :P
I say you stick with the plog and downpipe. You will have a no hassle quick install. If you are only doing a 3.4 pulley you will be fine.
Could probably handle a 3.5 pulley better with some extra timing and run smoother.
Biggest thing is you want a smaller pulley for boost, but not so small you have to sacrifice timing to run it... and NO KR!
