Re: 3.1L - Unusually High Fuel Economy Pohttp://www.grandprixforums.net/newrepssible?
Wow. SO much misinformation here...
First off I don't mean to offend se owners. But one, most are ugly, two a 3.1 isn't nearly as efficent or as durable as a 3800. The 3800 gets better gas milage according to Pontiac. Stick with the 3800
Pound for pound, the 60° 3.1 is MORE efficient, and just as durable as the 3800, not to mention sounds a ton better with aftermarket exhaust work. The only real downfall to the 3100/3400 motor was GM's retarded idea of using nylon/silicone for the intake gaskets, which were inevitably prone to failure. When the LIM gasket goes, depending on how bad the sepage is into the block, it can either lock up the motor, or the coolant destroys the bearings, leading to a spun bearing. Me and several of the ClubGP guys JUST witnessed a Grand Am GT pull into the shop we were hanging out at with this exact problem last night; 3400 BTW.
Really, no GM '96 & up is immune to this threat due to Dexcool eating away gaskets as well. Euro had to replace his 5x,xxx mile motor on his '00 GP GT last year due to the gasket giving out, and leaking coolant into the oil. He spun a bearing a few weeks AFTER the gasket was replaced. Luckily, he had the GM extended warranty.
I have a 3100 SFI in my car, and I get 30 mpg city. I usually fill up once a every 2 weeks and I drive a good 50 miles a day to n from work.
You have a gen I w-body, which is lighter. That could explain a slightly better fuel economy, but....even with that, 30 MPG city is crazy. Hell, even for highway, that's up there considering it's still well over 3,000 lbs. You've definitely got a freak of a car there.
And I get 17 mpg drivin like an ass. Upwards of 26 mpg on the highway and 18-19 on average
I usually average 32 - 36 highway, and 20 - 23 city in the GTP if I'm not getting on it. If I'm a bit antsy to get somewhere, it might dip down to 26 - 30ish, and 17 - 20. They can definitely achieve better than the EPA estimated (which is true in most cars' cases).
GM stopped producing the 3100 because they were money pits. They ended up putting more money/research into the 3400. Now, its one of the best motors they make. The 3800 is great and everything, but not everyone needs the power. If I could go back and buy a GP with what I know now, I would've never even THOUGHT of buying a 3100...
What the hell are you talking about? The 3100 and 3400 are basically the same motor. It's a slightly bored out 3100. Hell, the '00 and up 3100 even got the same bigger upper and lower intake manifold ports as the '96 & up 3400, and they never differed much in power (3100 peaked out at 175hp, 3400 eventually made its way up to 185hp). BTW, you do realize they stopped making the 3400 after '05, right? You said it's the best V6 they make, as if they're still making them. Oh, and you do realize they got rid of the 3100 "money pit" at the same time, not earlier, right?
They are no more of a money pit than any other GM motor, including the 3800. The only thing they're a bit more prone to than other GM motors is LIM gasket failures, due to the reasons I stated earlier. So long as you change those out with the updated gaskets before disaster strikes, you should be fine. Otherwise, the rest of the common issues with those motos are common amongst just about ANY GM motor, and no GM is safe from LIM gasket failures by any means, either.
The reason GM moved on is called progress. The 3.1 replaced the 2.8, the 3100 replaced the 3.1, and the 3400 was a bored out 3100. It's evolution. As the need for a more powerful motors arises to take on competition, and more technology is developed to take on this challenge, things change. It is the reason the severely outdated 3800 was FINALLY put to rest, and replaced. The 3100/3400 were based on an outdated motor (just like the 3800), and GM needed to scrap them in favor of something more cutting edge (3500/3600/3900, all of which are 60° motors, btw).
Michael, do you know what the actual MPG your friend is getting in his Montana is? Discussing gas mileage in the form of how long it takes each of you to fill up doesn't really give us much of a context to go off of.
