We have a 2007 GP Base with 170,000 miles, and it has a pretty good coolant leak. If you look under the hood on the pulley side, you can see it just about everywhere, like it must be spraying while it's running. On the belt. other pulley's, cables, etc. I have to admit I do not know which one is the water pump, but it looks like it may be starting where the hose from the lower radiator (passenger side) runs up into the engine. The hose looks tight, and doesn't appear to be leaking. I stuck my hand down there and it was sticky, but not wet.
We're going to be taking it in Friday, but I wondering if there was something you guys could think of that I could check? Or any thoughts as to what it could be?
