2005 GP GTP battery
lawadm1
So the battery finally died in my 2005 GTP, and I'm attempting to replace it but I find that you must remove some things to get it out. My question is how do you remove the bolts that the black box (sorry, don't know the tech term for it) is bolted down with? They just keep turning and turning. It's almost like you have to get in the wheel well to keep the screws from turning.
And then I'm assuming that you have to also remove the washer fluid container?
Any help is appreciated. Thanks.
To remove the battery? You only need to unbolt the black piece that is holding the battery down at the case and the bar that crosses on top of the battery. That's it. And of course the wires that go to the battery.
Are you talking about the GTP that you only have to remove the bar? Because the fuse/relay needs to be removed or I can't get the battery out. Too small of an opening.
