This car is new to me so i am not familiar with its quirks
The right rear caliper was leaking, so i got a good looking
one at u pull it yard. Piston seemed to screw in OK and the
boot looked OK. Pads were about shot on my car so i bought new ones.
Took the old one off and did the swap. the emergency brake cable
was seized so it just cut it off and left it off. Originally when i took
the old caliper off, i had issues with the lower caliper slider coming
out. It would turn around, but did not want to pull out. after some persuasion,
i got it out. There was lube in the hole and it was not seized, but it really did
not want to slide out. This pin had the plastic sleeve on its inner tip.
i cleaned off the pin and put some new caliper rated lube on it.
I had to kind of fight it to get it back in. It would move in and out,
but it had more friction than the upper pin. (the upper pin had no sleeve
on its tip and freely pulled in and out).
Put it all back together and bled the brakes. the right rear wheel has to much drag
in it. car drives OK and stops OK, but i know the extra drag is not good.
The right rotor is also warmer than the other side taken on short test drives.
So the question is what is wrong? should that pin with the plastic bushing
on the end push in and out a LOT harder than the one that does not have
the bushing? I did spin the caliper piston all the way back in (or so i thought)
with a cube tool.
Look for suggestions when i take it back apart. I am smelling that pin with the
bushing on it is deformed (looks OK) or the bore it goes into has issues.
How much more friction does the sleeved pin have vs the top one with no sleeve?
bob
with a cube tool.
bob
