2003 GP SE won't start
trbowgn
I picked up this car about 3 months ago. I have replaced the battery as well as repaired the stripped rocker arm. The car has been fairly flawless since completing the 2 needed items. Last night I drove the car to dinner and parked it once home. Then this morning I went to start the car and it just cranks. I figured it wasn't getting spark or fuel. I can hear the fuel pump turn on when the key is to the on position. I first replaced the fuel filter. While the filter was off I performed a non recommended idea of putting the key to the on position to verify the pump was actually working. It was.:th_laugh-lol2: Anyways hooked it all up, turned the key and it just cranked. Then I replaced the fuel pressure regulator. Still just cranks. I have spark across the front 3 cylinders and really just assuming that if there is spark up front the rears are also getting spark. I have replaced 1 coil pack too. So then I went onto replacing both crank position sensors. And it still only cranks. I have a cam position sensor, but I'm not looking forward to taking the manifold apart. Is there anything else I am over looking possibly? I think I have covered everything, but just want to make sure.
