I just installed two new OEM GM headlight assemblies on my 2002 GP GT. I noticed like the original ones I took off that the passenger side assembly feels loose compared to the drivers side one.
It is not loose where it is mounted but overall it feels loose at the bottom, compared to the drivers side assembly.
The passenger side one wiggles around more at the bottom.
I got the car new in early 2002 and noticed this alittle after the warranty ran out , that the passenger side assembly would "bounce" as you drove down a rough road ,you could see it in the headlight beam hitting distant objects ,but the drivers side did not.
A friend and I checked everything ,assembly dimensions , mounting ,etc. and both sides checked OK ,why does this passenger side assembly have a "looser fit " at the bottom then the drivers side assembly ?
Now with new OEM assemblies ,same problem ?
Anybody experience this problem ,if so what did you do about it ?
Al
Al
