baddestGTP
Price: $4,000
Photos posted here: StockPrixSale - Google Photos
Videos posted here: StockPrixSaleVideos - Google Photos
Price is FIRM. I spent over $3k in 2018 returning it to stock from a turbo build using a donor engine/trans from a 2004 Buick Park Avenue Ultra, making some repairs, etc. If it doesn't sell for asking price I plan to keep it as a spare car for the family and store it at my sister's place. The car hasn't been a daily driver since the summer of 2008. After completing the demod and working out some kinks, I drove the car everyday for 6 weeks with NO issues. After a recent detail, it is now ready to go.
General details:
* 2000 Pontiac Grand Prix GTP 4 Door - Black
* Mileage
** Body - 129,763
** Engine/trans - 90,990
* 3rd owner
** 1st and 2nd owners in California
** Purchased from 2nd owner in June 2004 with 82,XXX miles
** Car was in Michigan for 3 years before I moved to Florida. 2 winters it was not driven in snow often since I lived on campus. 3rd winter it was stored because I bought a winter beater.
* Body and all metal is solid, no rot.
* No accidents
Non stock items that are still on the car:
* MSD spark plug wires
* PVC hot air intake with ZZP 4" oiled air filter
* 180* drilled thermostat
* Fuel pump rewire kit
* 1.25" oversize radiator
* MSP TBv2 Polyurethane Upper Motor Mounts
* OEM lower motor and transmission mounts, drilled, drained and filled with polyurethane (Urethane Casting Compound, 1 Pound Liquid, Shore A 80, Black)
* Alternator Re-wire Kit
* Racetronix fuel pump (RX-W1-FPA) (ordered from PRJ)
* Exhaust
** ZZP 3" downpipe + 3" exit with 400 cell cat
** 3” midpipe to 2.5” offset outlet Y pipe
** Magnaflow Mufflers
* Suspension/Brakes
** ZZP/HT Motorsports Coilover Kit w/KYB AGX adjustable gas struts
** Kirkey Coilover protectors
** Front & Rear Sway Bar Upgrade
** BMR Fabrication Adjustable Front and Rear Strut Tower Braces
** BMR Fabrication Tubular Trailing Arms
** BMR Fabrication Adjustable Rear Lateral Arms
** BMR Fabrication Adjustable Forward Lateral Arms
** BMR Polyurethane Bushings replaced November 2014
** Front and Rear Camber Adjustment Kits
** SP Performance Nickel Plated Front 12” Drilled and Slotted Rotors
** SP Performance Nickel Plated Rear Stock Slotted Rotors
** Hawk Ceramic Brake Pads
** Goodridge Stainless Steel Brake Lines
* Appearance
** SD Ram Air Hood
** SLP Generation 1 “Whale Tail” Rear Spoiler
** Lloyd "Grand Prix" black/red floor mats
** Ram Air Tech Hi-Polished Billet Aluminum Engine Supports
** Ram Air Tech Hi-Polished Billet Aluminum Side Supports
** Blazer Tech 3200 Driving Lights
** Muth Side View Signal Mirrors
** 20% tint all around (retinted in December 2014, perfect condition)
** Street Scene 4 Piece Chrome Grill Set - Spray painted silver
* Audio
** Alpine CDE-HD149BT head unit
** Monster XLN RCA Interconnect Cables (4 channel for front/rear speakers + 2 channel for subs)
** Pioneer GM-D9605 Gm Digital Series Class D 5 channel amp
** Infinity Kappa 50.11CS 5-1/4" component speakers in the front
** Infinity PR9613IS 3-Way 6x9 speakers in the rear
** Kicker 11S10L74 10" Solo-Baric L7 4 ohm subwoofer in ported enclosure
** Dynamat complete cover of trunk, rear seat, rear deck, and doors
Miscellaneous:
* Custom cut center console with dual Aeroforce scan gauges and Autometer angle rings
* Big 3 upgrade
* Electrochromatic rearview mirror with compass
* L26 aluminum oil pan
* 3rd brake light removed
Relevant major maintenance + mechanical history:
* 89,624 miles on donor L67 engine/4T65E-HD trans when installed
** New OEM spark plugs installed
** Mobil 1 10W-30 full synthetic oil + K&N oil filter (changed again at 90,125 miles)
** New OEM trans filter and Dex 6 fluid
** All other fluids (coolant, power steering, brakes, etc) were also replaced during the donor engine/trans transplant
* Rebuilt rack & pinion from Rack Doctor + new (not rebuilt) OEM power steering pump installed in early 2011
* AC compressor and related parts replaced September 2011 @ 125,536 miles
* Sumitomo HTR A/S P01 98V tires (225/60R16) installed November 2014 @ 127,892 miles
* WBS OEM replacement axles with high quality CV joint boots (no leaks)
* VTD (Vehicle Theft Deterrent) module replaced summer 2011
Other included items:
* Helm's Service Manuals (full set) for year 2000
Issues:
* Gas pump nozzle must be turned at an angle to fill gas tank at full speed - I suspect the rubber fill hose section is collapsing due to old age, but have not investigated yet.
* SRS airbag light is on - Clock spring in steering column needs to be replaced
* Paint vandalism (6 deep scratches on hood, driver door, passenger rear quarter panel) - See close up pictures and video
* Fading paint on rear spoiler - See close up pictures and video
* Passenger front corner light seal is bad
* Both rear tailight seals are bad
General details:
* Mileage
** Body - 129,763
* 3rd owner
* No accidents
* Exhaust
* Suspension/Brakes
* Appearance
** SD Ram Air Hood
* Audio
Miscellaneous:
* Big 3 upgrade
Issues:
