    TIPS:
2 Sets of NEW EV1 42lb Green Top Injectors
Status
Not open for further replies.
Blake71091
NEW.
Shipping from 55369 Minneapolis, MN.
SOLD both sets in about an hour lol.
Thanks.
Body: Metal & Composite plastic factory fitted with Viton upper & lower O-rings.
Resistance: 14.5 ohms
Flow Rate in LB per hour: 42 LBS/HR at 43.5 PSI
Flow Rate in CC per minute: 440 CC/min at 43.5 PSI
Pressure: Min 30 PSIG / Max 100 PSIG
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: 1.0 Amps
Length: 3 inches, 74 mm
Diameter: 24 mm
O-rings: on both Top and bottom about 14.5 mm
They are BWD brand.
Sold both in less than an hour to REDCOMPG & CapnBreakAlot.
Will PM you guys tracking tonight after I ship tonight!
Status
