2 problems with my driver seat!
The 1st problem would be that my forward adjustment function does not work. Up down and back work no problem.
My 2nd problem woul be that my heating element takes forever to heat up. About 20 30 mins estimated then its hot af
Sent from my SM-G900V using Tapatalk
Likely the heating element is partially broken. Take a look at the write up under my name for heated seat repair and that should guide you on what might be the issue.
As for the adjustment, is this a manual or power seat?
