    TIPS:
2.5" catback Antioch IL 60002 pickup
ItHurtz
Active member
2.5" catback mandrel bends tubing, 2.5"magnaflow round muffler, 2.5" flowtech afterburner mufflers, stainless slant rolled tips 4"outlet.
Located in Antioch IL 60002
paypal as gift or you eat the %, or cash only
$250 is a good starting point, trades meh dont need much of anything.
Will NOT ship, pickup is preferred, cant guarantee if I can meet halfway as I can get super busy at time.
Come with a way to bring it home or bring your own saw to cut it up as I will not cut it for you.
Originally was installed with the blower and sd headers, catless, was last on turbo and catless. Moved to 3" so this had to come off. Under 10k miles.
The right tip as seen in vid has to come down 1/2" (exhaust is welded) the round muffler interferes with the rubber "orings" that hook underneath, I used a metal support bar connecting to both hooks or you will have to weld hooks to the magnaflow to use that oem mounting rings.
This was designed as a bolt on for MY car, catless, flex deleted sd headers w 45° replacement so those with cats I am not sure on any modification or if any is required to get that front area to connect. The rest of the oem hangers should fit as I didnt change any mounting locations.
The only clip of the sound, please note that the car in the vid is TURBO not SC and will not produce the same tone on a SC car. Turbo toned down the exhaust alot. While setup up on the 3.4 pulley the blower does scream louder than the exhaust, it is not a loud setup, does not have rice, crack, pop or any other bull****. To my ears it has a good tone, unique, not stock quiet but just enough to say its not stock. No problems talking to your passenger at any speed.
P.S tips could use some more cleaning to shine like new.
https://www.youtube.com/watch?v=dGomgsR2dSk
20150817_171022 by Corey S, on Flickr
20150817_171032 by Corey S, on Flickr
20150817_171050 by Corey S, on Flickr20150817_171056 by Corey S, on Flickr
20150817_171132 by Corey S, on Flickr
